HELP! Composite logger, Toth Logger, etc DON'T WORK.
Postby EnricGuardiaSinfreu » Mon Mar 27, 2017 1:32 pm
I get this:
"Empty read, No Data Received from Controller"
MSII V3.0 with a new msextra firmware. The rest works perfectly, I can get signal from MAP, TPS, thermistors (RPM on the way)...
It's really hard to sync RPM without that, I know I could do that manually with an oscilloscope but mine is quite slow using both channels.
Which can be the problem? Firmware? computer? cable? ms2 daughterboard?
Thanks!
EnricGuardiaSinfreu
Re: HELP! Composite logger, Toth Logger, etc DON'T WORK.
Postby slow_hemi6 » Mon Mar 27, 2017 1:54 pm
Cheers Luke
slow_hemi6
Postby LT401Vette » Tue Mar 28, 2017 7:03 am
If it is getting empty reads, the MS may not be seeing any signal for the crank. Pots?
Postby EnricGuardiaSinfreu » Tue Apr 04, 2017 3:26 am
Thanks, I solved this when I finally synchronized RPM
EnricGuardiaSinfreu
Postby whittlebeast » Tue Apr 04, 2017 4:00 am
I was seeing that when I was chasing sync issues. Sometimes I would get nothing.
I still can't seen to get a MAP log. The pages never start piling up.
ANdy
whittlebeast
Postby EnricGuardiaSinfreu » Thu Apr 06, 2017 12:04 pm
whittlebeast wrote:I was seeing that when I was chasing sync issues. Sometimes I would get nothing.
ANdy
In the composite I only get RPM, CAM and sync loss. No TPS, no MAP, no O2...
idk
EnricGuardiaSinfreu
Postby whittlebeast » Thu Apr 06, 2017 12:30 pm
A Composite log is a little funny to read. Post yours here.
Here is one off my car.
http://www.nbs-stl.com/CrxTypeR/40%20to ... %20log.csv
Andy
whittlebeast
Postby jsmcortina » Thu Apr 06, 2017 4:06 pm
EnricGuardiaSinfreu wrote:In the composite I only get RPM, CAM and sync loss. No TPS, no MAP, no O2...
That's correct.
If you want a normal datalog, then go to Datalogging -> Start Datalogging
Return to Tuner Studio
