Hi All
I've had a search but not seen my issue anywhere. I got my Bluetooth module setup and configured last night and it works great. I've created a custom dash (I tried to attach the dash but it's too large) which has circular analogue gauges. My issue is that in TS, the gauges are circular bars that fill as they go around. In Shadow Dash, the needles become wedge shaped indicators that move around and are much harder to see.
Is anyone able to say why the needle type changes between TS and SD?
In TS:
TS/SD Gauge Needles Different
Re: TS/SD Gauge Needles Different
That sounds like the difference between the "Analog Bar Gauge" and the "Analog Moving Bar Gauge"
Is SD picking up the wrong one?
I will investigate
I will investigate
Yep, just verified Shadow Dash 1.5 is picking up the wrong renderer for Analog Moving Bar Gauge.
I'll get that fixed.
Awesome, thanks for the quick response! Really looking forward to giving this a go!
