can't connect MS3x to tunerstudio
ejs262
Post by ejs262 »
I'm having trouble getting my MS3x to connect to tunerstudio,
I open tunerstudio
file>new project
then click "detect" under firmware.
then I get this:
I've tried going through multiple usb ports, as well as a serial to usb adapter (keyspan)
I have verified power and ground to the MS3x, so I am assuming there is a configuration issue in the tunerstudio, any ideas?
Thanks-
Eric
"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
slow_hemi6
Re: can't connect MS3x to tunerstudio
Post by slow_hemi6 »
I would say you are up to step 2.7 http://www.msextra.com/doc/pdf/html/Meg ... .5-15.html Go from there.
Cheers Luke
ejs262
Post by ejs262 »
I've tried installing/updating the drivers, and am getting the same results... I can get the com port and usb serial converter to show up in the device manager just fine, everything looks like it should per the manual, but I'm just not getting a connection. I've tried swapping usb ports, and cables too, nothing. port check also says no connection found. I'm starting to wonder if my MS3x is a dud...
Post by LT401Vette »
Is this an MS3 you built yourself or bought?
Do the LED's light?
have you ever connected to it?
ejs262
Post by ejs262 »
LT401Vette wrote:Is this an MS3 you built yourself or bought?
Do the LED's light?
bought it assembled.
on my MS3x, there weren't any external LED's to check
no, I haven't, this was my first attempt.
slow_hemi6
Check with who you bought it from. It may need firmware to be loaded.
Cheers Luke
ejs262
Post by ejs262 »
slow_hemi6 wrote:Check with who you bought it from. It may need firmware to be loaded.
how would you do that if you can't connect to it?
ejs262
Post by ejs262 »
ugh....
not sure what that guy is, but I'm pretty sure it's not supposed to be that color, I also think that means the x part of my MS3x is toast... wonder what caused this...
