I have seen this error several times trying to view a posted msq.
David
Can't View MSQ
Can't View MSQ
Re: Can't View Posted MSQ
Normally EFI will have a solution but nothing pops up for this, what is the reason I can't view this msq?
David
David
Re: Can't View MSQ
That would be an ini file that TS downloaded from the server.
My guess is that perhaps it did not get the whole file or it became corrupted?
Try deleting that ini file and let it try again.
Re: Can't View MSQ
It could also be another problem, perhaps send us your TunerStudioAppDebug.txt after getting the error message.
Re: Can't View MSQ
Thanks Phil, I will do so next time I have this problem.
David
David
