Struggling to connect
HI i'm experiencing some difficulty trying to connect to TS, i get the error "receiving invalid data from controller" it will eventually connect and one i'm in all is good. Im using USB-a to USB-b cable for comms has anyone else had this issue
Re: Struggling to connect
If you can capture a Comm Debug log of TS trying to connect.
- Close TunerStudio.
- Using File Explorer, navigate to your TunerStudioProjects folder
- Delete the file "TunerStudioAppDebug.txt"
- Open TunerStudio, but not the project.
- On the main menu check "Communications --> Comm Debug"
- Open your project and let it try to connect
- Close TunerStudio
TunerStudio will now have recreated the TunerStudioAppDebug.txt with the needed information.
Post that here.
- Close TunerStudio
Post that here.
Thanks for the reply, this time took about 10 second but i can take up to a minute sometimes
I do see an issue. I will set up a box with this older firmware to try reproducing.
I will investigate and have more for you tomorrow.
I have updated the firmware now to the 1.5 and this seems to have cured the issue. Thanks for the reply
