Windows version
TS 3.0.18 detects, downloads & installs new version & auto-restarts.
Updated version still says 3.0.18 & will detect a new version & go though procedure again & again.
Same thing for Full or Lite versions.
Same thing happened a few revs back, I think it was a server problem & Phil fixed it.
If if you select "Check for Update" , then "Update Later", it responds with "No Updates Available, 3.0.18 is the latest version".
Manually upgrading does work by downloading it from here:
http://tunerstudio.com/index.php/downloads
BTW, it says 3.0.20 when it actually is 3.0.21
Never did get 3.0.20.
Better check the Change Logs, too.
http://www.tunerstudio.com/index.php/do ... ngelogmenu
2017-01-16 - Released 3.0.20 for auto-update and download as beta and stable.
Probably should be 2017-04-16
BTW, in Help---About, change copyright date to 2017
TS 3.0.21 Update Problem - SOLVED
Re: TS 3.0.21 Update Problem
For reference, I just auto-updated from 3.0.20 to 3.0.21 on Linux ok. From the UK.
Just loaded TS again & it auto-updated my Lite.
All fixed now, except for this:
It said it was updating to 3.0.20, but it's 3.0.21.
Just noticed something, probably there for a long time.
Alt-F, X won't exit TS, i.e. no shortcut key command to exit.
No problem with TS 3.0.22
2017-04-28 - Released 3.0.22 for auto-update and download as beta and stable.
2017-04-28 - Fix Difference Report comparing 1 digit more than set precision on F32's.
2017-04-28 - Disabled parsed ini caching.
