Not sure if this has been discussed before. Feel free to delete if needed.
One thing I constantly run in to is switching to the 3d view, seeing something I want to look at, and trying to then pick that cell out in the 2D view. Would it be possible to share selections between the 3D and 2D views? So if you select a number of cells in the 2D view and switch to 3D those cells will then be selected in the 3D view. And vice-versa.
Feature Suggestion: 3D view cell selection
Re: Feature Suggestion: 3D view cell selection
Anything is possible, but that is not trivial as they are 2 separate widgets and the 3D table doesn't yet support multi select.
that is on the todo list though to get done.
