Injector size
Injector size
Postby maych87 » Fri May 12, 2017 9:10 am
I have a 1989 Porsche 911 with a 3.6 l. I am setting up the injector size in tuner studio. Porsche runs a much higher fuel pressure than 43.5 psi that most injectors are flow tested at. Do I use my injector flow rating at 43.5 psi or what they are rated at for my vehicles fuel pressure?
Sent from my iPhone using Tapatalk Pro
maych87
Re: Injector size
Postby grom_e30 » Fri May 12, 2017 11:11 am
the flow rate they will be at in your install.
grom_e30
Re: Injector size
Postby maych87 » Fri Jun 09, 2017 11:11 pm
The manual says 55psi engine off pump running. And 48psi engine at idle. Which is the proper psi to use?
maych87
Re: Injector size
Postby DaveEFI » Sat Jun 10, 2017 1:56 am
You use the higher one. That is the pressure at full throttle.
DaveEFI
Return to Tuner Studio
Users browsing this forum: Bing [Bot] and 2 guests
