Tach settings
Tach settings
Postby 107merc » Fri May 12, 2017 9:30 am
I'm setting up a tach output to drive my existing tach using JS0 jumpered to IAC1. Went into Basic Load Settings/Tacho Output
and assigned IAC1 as the output. Do I still need to go to ON/OFF Outputs and enable IAC1 or is it connected??
Thanks.
107merc
Re: Tach settings
Postby grom_e30 » Fri May 12, 2017 11:10 am
In the tach settings only, if you enable it in that and the on/off ports you will get a config error as you are trying to use the same output twice
grom_e30
Re: Tach settings
Postby 107merc » Fri May 12, 2017 1:03 pm
Thanks.
107merc
Return to Tuner Studio
