Tach settings
107merc
Tach settings
Post by 107merc »
I'm setting up a tach output to drive my existing tach using JS0 jumpered to IAC1. Went into Basic Load Settings/Tacho Output
and assigned IAC1 as the output. Do I still need to go to ON/OFF Outputs and enable IAC1 or is it connected??
Thanks.
grom_e30
Re: Tach settings
Post by grom_e30 »
In the tach settings only, if you enable it in that and the on/off ports you will get a config error as you are trying to use the same output twice
107merc
Re: Tach settings
Post by 107merc »
Thanks.
