Feature Discussion/Suggestion: VEAL Auto-Smooth
Postby 5.0Thunder » Fri May 19, 2017 11:43 am
As we utilize the VEAL tool during tuning, the map generated can typically be peaky. After every tuning session I go inside and smooth things out manually based on what the engine is wanting in certain areas and if those areas were swept a lot during the session. Would it be wise to incorporate auto-smoothing into the VEAL feature that factors in hit-counts, interpolations between cells, etc.?
I'm about to have some load bearing dyno time where I want to experiment with using VEAL while targeting single cells and the auto-smoothing feature would be handy here. I think i'd basically be able to just let the engine run in each cell and not really touch anything but the "save" buttons.
5.0Thunder
Re: Feature Discussion/Suggestion: VEAL Auto-Smooth
Postby rukavina » Sat May 20, 2017 10:51 am
I also have a suggestion.... with Ms you can toggle outputs on and off to test. I don't know of that function on this board. I was able to test the controller I just built by faking a vss signal and running it thru it's paces but it would have been nice to just turn things on and off while on the bench...
4wheel drive 454 vortec on ms2 w/gpio for 4l80e Trans control
rukavina
Postby 5.0Thunder » Thu May 25, 2017 9:39 am
^^ May be better to post a new thread since that's a different feature.
5.0Thunder
Return to Tuner Studio
