Feature Discussion/Suggestion: VEAL Auto-Smooth
5.0Thunder
Post by 5.0Thunder »
As we utilize the VEAL tool during tuning, the map generated can typically be peaky. After every tuning session I go inside and smooth things out manually based on what the engine is wanting in certain areas and if those areas were swept a lot during the session. Would it be wise to incorporate auto-smoothing into the VEAL feature that factors in hit-counts, interpolations between cells, etc.?
I'm about to have some load bearing dyno time where I want to experiment with using VEAL while targeting single cells and the auto-smoothing feature would be handy here. I think i'd basically be able to just let the engine run in each cell and not really touch anything but the "save" buttons.
1990 Mustang: MS3Pro Gen 1, 306ci, 72mm turbo, 80lb inj, 36-1 + Cam Sync + D585 coils, World heads, TFS1 cam, GT40 intake, auto, Speed Density
1987 Mustang: MS2v3.57, direct coil control, MSD VR Dizzy, SBE, Weiand 174,190cc heads, F303 cam, TBI w/ (4) 160lb inj, GT500 MAF
rukavina
Re: Feature Discussion/Suggestion: VEAL Auto-Smooth
Post by rukavina »
I also have a suggestion.... with Ms you can toggle outputs on and off to test. I don't know of that function on this board. I was able to test the controller I just built by faking a vss signal and running it thru it's paces but it would have been nice to just turn things on and off while on the bench...
4wheel drive 454 vortec on ms2 w/gpio for 4l80e Trans control
5.0Thunder
^^ May be better to post a new thread since that's a different feature.
5.0Thunder
Bump!
5.0Thunder
5.0Thunder
bump
sschutte
Post by sschutte »
Feature request received. Please give us a week to review and get back to you.
Schutte
martroy
Post by martroy »
What have you decided?
5.0Thunder
Never heard back on this one.
mapdaddy
Post by mapdaddy »
I've often wondered about this feature. Would be nice to enable and disable the smoothing if it was implemented.
vw_chuck
Post by vw_chuck »
There is already a smoothing function. Just go to the map, highlight and hit the button.
5.0Thunder
Woah, this will throw stuff out of whack. Areas that are perfect and already smooth will be elevated or decreased, throwing AFR's off. Idle area would be increased, lots of things you don't want to touch will be modified.
Using the hit count during VEAL and targeting only the cells around your corrected area should keep all that from happening. I'm sure there is a more elegant and useful way of doing it that these guys are working on.
Dennis_Zx7r
Post by Dennis_Zx7r »
Yeah, the smoothing should be limited to cells that have a very low hit count. However, this would require recording how often the cells have been hit in previous tuning sessions or you could only use it once.
My project: Link
5.0Thunder
Bump for update
