How hook up Bluetooth rs232 adapter from efi analytic
I have the ms3 pro ecu with DIY's plug and play 24x harness. Bought Bluetooth adapter from efi analytics and have an android tablet with shadow dash loaded on it. Question is how do I hook up the adapter don't see anywhere where I can just plug it in or is something that needs wired in?
Re: How hook up Bluetooth rs232 adapter from efi analytic
Your MS3-Pro would have come with a DB9 cable that plugs into the harness. That also supplies power on Pin 9.
Plug that into your harness, then plug the BT Adapter into that.
Ok found the cable that plugs into the 4 prong serial plug but the db9 connector on the other end is female just like the rs232. Guessing I need to find a male adapter or pin my own db9 connector. Thanks for your help
