Add new channel wizard issue Fuel pressure
gjestico
Post by gjestico »
Hello, I am trying to add a new channel for a fuel pressure sensor coming in on ADC7. I tried using the "Add channel wizard" . I selected AD7 as the input and named it "Fuel pressure" in the second box. I entered the numerical paramaters below, But when I hit the next button, Error window comes up "Output name cannot contain special characters". ?
67 Chevelle, LSX V8 engine, EFI., cuppa 80's TPI projects....I like wires.
whittlebeast
Re: Add new channel wizard issue
Post by whittlebeast »
Try FuelPressure or Fuel_Pressure
I think the <space> counts as special.
LT401Vette
Post by LT401Vette »
In the beta, it automatically swaps out spaces for _
gjestico
Post by gjestico »
That's_ (Underscore) the ticket ! thanks.
gjestico
Post by gjestico »
So I bought the upgrade to TS so that I could have a custom gauge (Fuel pressure) to display the readings from a sensor on ADC7. Works good when running tunerstudio.
But when I look at the logs with megalogviewer, The field is listed as ADC7 and looks like the raw bitcount. Do I have to buy something else to get is to display as Pressure units there ?
LT401Vette
The ADc7 field will still be logged as it was in raw ADC
You need to add a Data Log Field also to log the new OutputChannel you set up. If you added the OutputChannel in the wizard, there is an option to do this in the wizard.
Otherwise you can add them one at a time in the Custom Channel Editor with TunerStudio MS Ultra.
- Open the "Custom Channel Editor" under the tools menu
- In the tree on the left, click on "Data Log Field"
- Click the New button in the top left corner
- Set the name that you would like it to have in the data log.
- For OutputChannel, select the OutputChannel that you made for your Gauge, not adc7. Your OutputChannel is the one that takes care of the math for conversion
- Set the number of digits / decimal place you want it to log
- Click Ok
Now all future logs will have the gauge value.
http://www.tunerstudio.com/index.php/tu ... nel-wizard
gjestico
Post by gjestico »
Just wanted to add that I got this working, Both live gauge on TS and datalogged as the correct name. Thanks !
