Is it possible to re-start the timer in a triggered log, if the trigger condition happens again during that log? For example, I have my trigger logging to start with TPS > 80% and to log for 2 minutes as the stop trigger. I'd like to re-start the timer if during that log the TPS goes below 80% then back above 80%, so this way I can always log 2 minutes after the last TPS > 80% condition.
Trigger Logging Timer
Re: Trigger Logging Timer
I'm guessing there is no way to reset the trigger logging timer once trigger logging.
Weird bug:
I also learned that if you have the trigger logging setup to log on the timer then it is the same timer for regular (ctrl+l) logging. When I tried to log it would only log for the trigger logging stop timer duration.
I had to set the stop trigger to something other than the timer for the regular logger to log past my trigger logging stop timer setting or turn off trigger logging all together.
Weird bug:
Actually I believe I have addressed this in the current beta.
2017-05-31 - Triggered Logging: Set StopTrigger to not triggered when manually starting a log so the log will start even if the stop trigger condition is true. This way it will not stop logging until the stop trigger becomes false, then true again.
http://www.tunerstudio.com/index.php/do ... ngelogmenu
That is how it functions. If you set a condition to stop logging. It will honor that regardless of how the log was started.Weird bug:
I can see how you might have a different expectation if it is started manually though.
