Ford 2W IAC.
Ford 2W IAC.
the valve has to open against the spring or shut against the spring. What if you have no spring?? Thought I had a bad (new) unit but the IAC on my working
Ford van also has no spring. Any info appreciated.
Re: Ford 2W IAC.
From what I can see of it, that looks like a standard Ford idle valve.
Re: Ford 2W IAC.
It is. so what T/S setting should I use, normal or inverted. Thanks.jsmcortina wrote:From what I can see of it, that looks like a standard Ford idle valve.
Re: Ford 2W IAC.
Re: Ford 2W IAC.
Return spring is not visible on all of my Ford IAB's.
I've bench tested many of these. Spring is not that strong. You can easily blow through from inlet to outlet. Solenoid ON compresses the spring. Connect it directly to the car battery & watch it work. Just touch it, don't leave it on; it's not designed for 100% duty cycle.
TS setting
Valve Mode - Normal, 0% = off
Valve Frequency - 124Hz
TS setting
Re: Ford 2W IAC.
Thanks for responding, the plunger on mine is on the opposite ie; solenoid side.Blown88GT wrote:Return spring is not visible on all of my Ford IAB's.
TS setting
Re: Ford 2W IAC.
Mine, too.107merc wrote:...Thanks for responding, the plunger on mine is on the opposite ie; solenoid side.
