Tunerstudio problem
Tunerstudio problem
Hi guys need some help, I'm running ms1 v3 all has been ok etc.....just fitted some cams to my engine so wanted to fiddle with the ecu, tunerstudio has been updated to the latest version, I've had problems connecting my ecu but I finally have, but I've lost my registered version and I can't do anything at all in tunerstudio apart from look at the gauge cluster... No tabs for anything....
Re: Tunerstudio problem
Sounds very strange as tabs, etc are included with free version. I'd start from scratch and download TS again which may avoid a corrupt file.
Jim
Jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
OK, will try that. Thanks Jim.
Did you by chance put it in dash only mode?
Check the main menu:
Options --> Performance --> Dash Only Mode
That should be unchecked or you will not have anything but a gauge cluster.
Yep I'm a dick head lol I had put it in dash only mode whilst messing around.
Thanks for your help.
