questions on ms2 5.0 mustang auto tune feature vs a tune
Onebad90lx
Post by Onebad90lx »
Ok guys 85 mustang 5.0 nothing crazy, mild cam old school 69 ported 351 heads, with a vortech a trim, 30 pound inhectors etc, sees maybe 5 pounds of boost, the car has a safe tune in it that this guy wes did for me, the car runs fine point a to point b, but I assume the tune is very safe tune car just seems flat 3000 and above. so for 500 I could have a guy come out and I drive it he tunes it, or how about this auto tune feature I am not at all sure how it works but I have talked to others that love it and swear buy it, could I get some info please, save money and get me closer??? or spend the money
its not a race or track car a driver but I want it to run decent lol should see 300-350 at the wheels I would hope
5.0Thunder
Re: questions on ms2 5.0 mustang auto tune feature vs a tune
Post by 5.0Thunder »
Before spending any money or doing any tuning, you should take a datalog of your car in 3rd or 4th at WOT to see how much timing is in it, Air Fuel Ratio, etc. and we could determine if there is more left in it or if it's pretty close to a theoretical "max". VE Analyze Live is a powerful tool in the right hands but if you're already close to max power, no point in messing with it. Also no point in spending 500 when you don't know your baseline. Take the Datalog and know exactly what you've got.
1990 Mustang: MS3Pro Gen 1, 306ci, 72mm turbo, 80lb inj, 36-1 + Cam Sync + D585 coils, World heads, TFS1 cam, GT40 intake, auto, Speed Density
1987 Mustang: MS2v3.57, direct coil control, MSD VR Dizzy, SBE, Weiand 174,190cc heads, F303 cam, TBI w/ (4) 160lb inj, GT500 MAF
Onebad90lx
Can you guys give me directions on datalog doing doing and saving then how to attach it here
5.0Thunder
To save the tune out, select File>Save Tune As> *this is where you name it and select the location (like desktop for example)*
For a datalog, you'll go to the data logging menu at the top of Tuner Studio, select Start Logging, a window will pop up where you name the file and set the location (desktop again for easy access), and click Save. This has started the Datalog which will record everything ECU is reading/doing. Do your WOT pulls starting from Low RPM to Max RPM in 3rd or 4th gear, then select Data Logging>Stop at the top menu bar to stop the datalog. Now the datalog file has been created and saved to your desktop where it can be reviewed with Megalogviewer.
It's probably best to get the engine warm and have the car ready for a WOT pull before you start logging. That way the log isn't filled with a bunch of unused data.
You can upload these files to the forum with the "Upload attachment" tab. Try to have both files ready at the same time for us so we can review the log and help make adjustments to the tune at the same time, if necessary.
Onebad90lx wrote:Can you guys give me directions on datalog doing doing and saving then how to attach it here
See the "Forum help page" or click "Read help page here".
Onebad90lx
thanks guys will get to it Monday or Tuesday my next days off
Onebad90lx
is there a time limit on datalog? I have to drive to place I can actually do a 3 thrd 4 th gear pull
whittlebeast
Post by whittlebeast »
Not really a file size limit in TS but there is a posting limit in this site.
5.0Thunder
Don't start the datalog til you're ready to make the hit. you don't have to be datalogging on your way to the test area.
