Hi All,
Running MS3 v1.5, TS 3.0.22. Not able to view HP or Torque in SD card data logs. I have Power & Torque in the selected data fields and have Log Power Fields set to log HP & TQ on the Performance & Economy Fields page. VSS is working well, some calculated fields working MPG etc. When I try to view HP or Torque in ML Viewer there is no selection available for those fields to load them in the graph.
Thanks,
Dave W.
SD Datalogging HP & Torque
Re: SD Datalogging HP & Torque
Is HP and torque in a normal data log?
I haven't tried to log it on my PC. I am using this MS3 in an SCCA race car ( Harsh environment for PC).
I did not initially notice the footnote for required inputs, apparently I need VSS1 & VSS2 I currently only have VSS1. I'm working on getting an ABS WSS connected to the car.
