I generated the attached VE table using TS. As you can see TS returned a table with the last 3 columns set to 6000 rpm! Any thoughts on this?
EDIT: Also note that I was the one who set the idle bins to 46. TS did not return those numbers.
Generated VE Table
Generated VE Table
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Re: Generated VE Table
Can't see the problem, just add some intermediate columns, check your target AFR table and generate again. I probably used those tools a dozen times before I started road running.
Jim
Jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
What did you use for inputs?
What is the maximum RPM under general settings?
The wrong numbers of course!!! So.... is that a problem???LT401Vette wrote:What did you use for inputs?
I dumb thumbed the inputs and set both redline and max HP to the same number (6000 rpm)! Needless to say, TS didn't like that!
Corrected the numbers and voila!
Apologies for the false start!!!
