I was playing around with the AFR table generator and noticed that if I have my project set to use Wideband - Lambda the AFR table generator still uses AFR and if I click apply to the AFR table I will simply get 1.993 for each cell. I have set Stoichiometric AFR to 9.85 (rounded to 9.9) in general settings as well as choosing include AFRtarget.
I went back in and set the project properties to use Wideband - AFR and all is well. Am I doing something wrong? I tried a basic project as well as my own and both exhibited the behavior. This is TS 3.0.22 on Windows 8.1.
AFR Table Generator
AFR Table Generator
http://www.buildpics.org/
Re: AFR Table Generator
Thanks for reporting this issue. We have been able to reproduce the issue and will be working on fixing it.
Workaround:
1) Click Generate
2) Select all cells
2) multiply all cells by 0.06802721088435374149659863945578
3) Click Apply table
Schutte
Workaround:
1) Click Generate
2) Select all cells
Schutte
Thank you!
