aggregating custom gauge
there are some gauges in Tuner Studio which aggregate values like the odometer.
Is it possible to define an aggregating custom gauge ?
Re: aggregating custom gauge
Yes...
In the Custom Configuration Editor, the advanced OutputChannel editor;
In the list of functions you will see accumulate(..) and persistentAccumulate(..)
accumulate - Accumulate and sum the expression, this allows totaling distance, milage, fuel consumption, etc. The accumulated value is only for the session.
persistentAccumulate - Same as accumulate, except the accumulated value is persisted to the next session. Allows for an Odometer.
http://www.tunerstudio.com/index.php/ma ... -functions
I see, wonderful !
Thank you very much.
One more question:
What is the time base for the accumulation?
In other words: which unit must the accumulated value have?
XX/sec, XX/min, XX/h ?
The best data rate offered...
So if your current date rate is 50 reads/sec it will be 20ms
but how does Tuner Studio know the unit of the channel?
E.g. if I want to build an odometer based on vss,
the unit might be m/s or km/h, so time reference is per second or per hour.
There must be a general time reference for accumulation, maybe per second or per minute?
You can define the units when you define the OutputChannel.
It will accumulate the value of your expression each time...
so if you are accumulating a VSS in MPH, and the time since the last read was 25ms, you will need to do the math to determine how far you moved in that 25ms.
Example OutputChannels:
deltatime = { timeNow() - lastValue(timeNow()) }, "s"
distanceTraveledMiles = { accumulate( (vss1 / 3600) * (deltatime) ) }, "Miles"
Aahh, that's the trick.
Thanks alot.
Thanks alot.
works great!
Two more questions:
How do I reset the value ?
Neither "Reset Value" nor "Clear Acion" or "Reset Runtime Value" does work.
I assume aggregating only works when Tuner Studio is running ?
Two more questions:
Reset from the dashboard?
That should do it...
Yes, if offline there is no runtime data so nothing to aggregate.
From the dashboard; popup-menu "Reset Value": nothing.
Setting "Single Click Action" to "Clear Action", then click from the dashboard: nothing.
Setting "Single Click Action" to "Reset Runtime Value", then click from the dashboard: nothing.
Tuner Studio 3.0.27
Tuner Studio 3.0.27
I did a similar thing when I read this thread last week
I added an odometer (actually a tripmeter) by selecting output channel tsDistanceTraveledKilometersStored. IOW, didn't use a custom output channel, but an existing one.
To reset I used a single click - reset runtime value.
Works fine, when I click the odometer, it goes to zero.
Maybe it works because I used an existing output channel, I didn't
