Can't View MSQ
Can't View MSQ
Occasionally I can't view an MSQ, when this happens I get this message.
Three or four times I have gotten an error report (before this message appears) giving me the option to go to EFI Analytics for a fix.
After going to the site I still get this message, any one know what is happening here?
David
David
Re: Can't View MSQ
That looks like it didn't finish downloading the ini file, so it wasn't valid.
Re: Can't View MSQ
Surely an incomplete download should be detected and trapped to prevent this happening?
Re: Can't View MSQ
Is there anything that can be done or just live with it.LT401Vette wrote:That looks like it didn't finish downloading the ini file, so it wasn't valid.
David
Re: Can't View MSQ
If there is a Temp folder in TunerStudioProjects delete it.turbo conversion wrote:Is there anything that can be done or just live with it...LT401Vette wrote:That looks like it didn't finish downloading the ini file, so it wasn't valid.
Re: Can't View MSQ
Check and see if that file in the dialog does exist. If you delete it, it will download again.
Re: Can't View MSQ
Thanks, I will give it try.
David
David
