Cant connect - Tunerstudio RS232 to MS2 Extra
linards
Post by linards »
Hello everyone!
Can someone tell me what i am doing wrong/missing?
Tunerstudio v3.0.22
RS232 to USB, ECU - MS2 Extra 3.4.2
Driver: PL2303 Windows Driver (prolific)
In device manager COM1, tried 9600 and 115200 baud
Buffers - 1, also tried without FIFO
portcheck.exe - no connection made
auto detect in tunerstudio - no controller found
HyperTerminal - just blank, cant write anything
Tried 2 computers - Laptop and iMac
But the thing is my friend can connect with his laptop using same usb (win10)
Any suggestions?
rukavina
Re: Cant connect - Tunerstudio RS232 to MS2 Extra
Post by rukavina »
I read some time back about an issue with "fake" prolific chips from prolific. The driver sees it as not legitimate and sets a bit that disables device. If you roll back driver to one with a date of 2008 ( if memory serves me right) that driver doesn't disable converter. Worth a try.
4wheel drive 454 vortec on ms2 w/gpio for 4l80e Trans control
Blown88GT
Post by Blown88GT »
USB-serial adapter compatability list
http://www.msextra.com/forums/viewtopic ... ic#p475191
Post by LT401Vette »
linards
Post by linards »
Hmm, USB is working, i tried in hyperterminal and portcheck, i am getting signal back ( i Add it screwdriver to 2 pins :D)
But thats all... Tunerstudio & portcheck cant detect firmware
Yes ignition is on
I am confused :?
But when i connect USB to MS then i am not geeting back any signal in hyperterminal anymore, thats is right?
EDIT: Ok, looks like i dont get any voltage on connector (from ECU to PC) where it connects to pc
DaveEFI
Post by DaveEFI »
Where did you buy the USB to serial adaptor? If from an MS dealer, should be OK. Others may not. Have you got access to an older desktop with a proper serial port? If that works, it would prove your adaptor is at fault.
