Feature Request - Load Dialog change
Postby nd_mustang » Wed Jul 19, 2017 8:37 pm
I would like to be able to "Save Dialog" for, say, "Table 1" for fueling, and then "Load Dialog" and load the same numbers into "Table 3". Right now it won't do that.
nd_mustang
Re: Feature Request - Load Dialog change
Postby Matt Cramer » Thu Aug 10, 2017 7:42 am
This should work with the Table Export and Table Import buttons. If not, you may want to post this in the TunerStudio section of the forum as this is related to the tuning software and not the firmware.
Postby LT401Vette » Fri Aug 11, 2017 7:30 am
nd_mustang wrote:I would like to be able to "Save Dialog" for, say, "Table 1" for fueling, and then "Load Dialog" and load the same numbers into "Table 3". Right now it won't do that.
In every dialog there is a file menu.
That file menu has basically exactly what you are describing "Load Dialog Settings" and "Save Dialog Settings"
If you use that option to save, if save only the settings in that dialog to a .msqpart file.
The Load Dialog Settings lets you load either a .msqpart file or a full msq. If it is a full msq, it will still only load the settings in that dialog, all other settings in the msq will not be loaded.
There is more on this in the Help under "Single Dialog Save / Load"
Note: This feature is only in the registered version.
Postby KeithBoden » Fri Aug 25, 2017 9:51 pm
Rebin the destination table first if you want that to match. It is only 16 numbers and the tab key works nicely. Then:
1. Open Table 1
2. Select (highlight) all the cells
3. Ctrl-C
4. Open Table 3
5. Select the top left cell (may not even have to do that, I just do)
6. Ctrl-V
Camaro, Mark IV aluminum big block Chevy, 8.8l, Procharger F1-R @ 12psi, MS3Pro
KeithBoden
Return to Tuner Studio
Users browsing this forum: Bing [Bot] and 3 guests
