Feature Request - Load Dialog change
I would like to be able to "Save Dialog" for, say, "Table 1" for fueling, and then "Load Dialog" and load the same numbers into "Table 3". Right now it won't do that.
Re: Feature Request - Load Dialog change
This should work with the Table Export and Table Import buttons. If not, you may want to post this in the TunerStudio section of the forum as this is related to the tuning software and not the firmware.
In every dialog there is a file menu.nd_mustang wrote:I would like to be able to "Save Dialog" for, say, "Table 1" for fueling, and then "Load Dialog" and load the same numbers into "Table 3". Right now it won't do that.
That file menu has basically exactly what you are describing "Load Dialog Settings" and "Save Dialog Settings"
If you use that option to save, if save only the settings in that dialog to a .msqpart file.
The Load Dialog Settings lets you load either a .msqpart file or a full msq. If it is a full msq, it will still only load the settings in that dialog, all other settings in the msq will not be loaded.
There is more on this in the Help under "Single Dialog Save / Load"
Note: This feature is only in the registered version.
Rebin the destination table first if you want that to match. It is only 16 numbers and the tab key works nicely. Then:
1. Open Table 1
2. Select (highlight) all the cells
3. Ctrl-C
4. Open Table 3
5. Select the top left cell (may not even have to do that, I just do)
6. Ctrl-V
1. Open Table 1
3. Ctrl-C
4. Open Table 3
6. Ctrl-V
Camaro, Mark IV aluminum big block Chevy, 8.8l, Procharger F1-R @ 12psi, MS3Pro
