Page 1 of 1
How to reset fuel used gauge
Posted: Sun Jul 30, 2017 12:20 pm
by W126
I tried to set "Single Click Action" in Designer Mode to "Clear Action" and "Reset Runtime Value",
neither works.
BTW. whats the difference between both ?
Re: How to reset fuel used gauge
Posted: Mon Jul 31, 2017 9:07 am
by Brian H EFI
I am assuming that you are using a gauge with metric units, if so then what you need to do is add an additional gauge that is the SAE equivalent then set it to use the "Reset Runtime Value" option. Now to reset the gauge you are actually using reset the SAE equivalent gauge and both should zero out for you.
"Clear Action" is used to clear the action that you had been previously set where "Reset Runtime Value" is the action you are assigning.
Posted: Tue Aug 01, 2017 9:05 am
by W126
strange, but works.
Thank you very much.
