Need Config Error Added
Postby Rick Finsta » Wed Aug 02, 2017 4:28 pm
Phil/Brian-
Check out this thread:
viewtopic.php?f=131&t=66841&p=508176#p508176
Running his tune on my MS3X and a Stim, I was getting the secondary stage on INJ2 instead of the 3X outputs (evidently the firmware won't allow this on anything more than a 4-cyl). I think there should be a configuration error popup in Tunerstudio for this situation, when you try to use the "Use MS3X (if possible)" option for a non-possible option. I got his setup working on the stim by running the primaries on the 3X outputs and the secondaries on INJ1/INJ2.
Let me know if you need additional information, but this was a frustrating one because the manual does say you can't do this with more than four cylinders, but the software lets you attempt it.
Rick Finsta
Re: Need Config Error Added
Postby racingmini_mtl » Wed Aug 02, 2017 5:59 pm
The config errors are detected in the firmware not TunerStudio. You need to post that in the MS3 forum.
racingmini_mtl
Postby Rick Finsta » Thu Aug 03, 2017 2:21 pm
Thanks, will do!
Rick Finsta
Return to Tuner Studio
