laptop hangs up
laptop hangs up
Ok I know this is not the first time for this. I'll try to be more creative next time. My Toshiba laptop Win 7 hangs up on TunerStudio. If I power up the controller first then the laptop it usually will go on-line, then as soon as you try to do something it hangs. Then its Task Manager and start over. Please lead me to the light!
Re: laptop hangs up
Do you mean TS completely hangs and you have to kill it in Task Manager?
How are you connected to the controller?
Re: laptop hangs up
Yes that's exactly what I mean. Good guess. I am connected thru a USB to RS 2232 converter.
Re: laptop hangs up
What kind of USB to RS232 adapter?
Can you post / send a Debug Package? (Under the help menu)
Re: laptop hangs up
Thanks again for your response. I will try today to get on-line long enough to run one.
Re: laptop hangs up
I am not sure I know how to do this? I have the debug file how do I pm it to you?
Re: laptop hangs up
email it to support <at> efianalytics. com with link back to this post for some context.
Re: laptop hangs up
I got your AppDebug.
Best I can tell it hung while opening a Calibration dialog.
Does it hang for any dialog, or just particular ones?
If you do nothing, does it continue communicating with the controller?
Re: laptop hangs up
I sent the de-bug file a few days ago to efi analytics. Did you get and if so have you had a chance to look at it yet. Thanks
Re: laptop hangs up
LT401Vette wrote:I got your AppDebug.
Re: laptop hangs up
If you just go on-line and start the motor and don't do anything it stays connected but pretty much anything you touch hangs it up. Especially if you try to change RPM redline?? I've tried to change the temperature calibration and sometimes it hangs up.
Re: laptop hangs up
Can you send / post a TunerStudioAppDebug.txt?
Re: laptop hangs up
I thought that was what we were talking about. It is rather large I sent it to EFI Analytics.
Re: laptop hangs up
I'm at a bit of a loss here. I think you do have a 1st here..
It sounds like this is more of a UI issue, not comms related.
Can you open dialogs when it is offline?
