Not sure what happened, but now TunerStudio takes several minutes to go over the "Loading Project".
Build: MS(Beta) v3.0.28.
Attached Debug file for this execution.
I suspect something like a timeout for BT? But that didn't happen before.
Thanks!
TunerStudio takes ages to actually load the project
Re: TunerStudio takes ages to actually load the project
It looks like there were a couple instances of TS.
The biggest delays see to be in trying to access a BT Adapter. The instances my be competing.
Are you using BT with this project?
Try making sure all T's are dead, either reboot or kill any java.exe in task manager.
turn off your BT on the laptop.
Does TS start normal then?
Yes, I did start another TS, but it's the same with just one.
With BT off on my computer, it starts quickly.
Turn BT on, and it takes a while, but seems to be faster, for some odd reason?
With this speed (30s maybe) I can leave with.
Cheers!
Cheers!
Hmm, 30s is still pretty long for a project load .
These last times (after I disabled BT on the computer and enabled it again) it's taking around 15/20s
It's long, but it's not 5m Do you want me to do any troubleshooting to help you out with anything?
It does seem that it's the BT fetch that is taking too long.
This didn't happen before I updated.
