Rolling back to previous versions
I am wondering if it is possible to roll back to a previous version of Tunerstudio
5 days ago I uploaded a new tune into my megasquirt with no issues..
The next day I connected my laptop and opened TS it automatically installed a new update from version 3.0.2 to 3.0.28
Now I am unable to get TS to communicate with my ecu... Port check shows the connection... I thought maybe I should update the firmware , so I did.. no issues with that.. but I still cannot get it to communicate with TS. Is there anyway I can roll back to the last version of TS which worked..
Re: Rolling back to previous versions
Are you getting any error?
Are you sure you updated from 3.0.2? (That is quite old and never a public release, the more recent stable version is 3.0.22)
Can you create a TunerStudio Debug Package from under the Help menu?
My Error is
"error reading data from My Car after 9 attempts
error message returned
could not process comminstruction
error written to log
timeout after 401ms . requested timeout :400, expected bytes:260, bytes read :89
I have enclosed my debug file as requested
Where?Intimidation 86 wrote: I have enclosed my debug file as requested
Ok, so it sounds like you are connecting fine, but it can not successfully read the tune data.
I uploaded the zip file using the upload attachment button below
I'll try again tonight
here is the debug I was asked for
thanks
thanks
That debug package does not have your project in it. Was the Project not open?
No project means I can't see how things are setup.
Also it would be good if Comm Debug was turned on for a connection try..
However, what I can see in the log is that it is indeed finding the controller just fine, but gets a timeout on every attempt to read tune data.
The main thing that can cause this is if in Project Properties CAN_COMMANDS is turned off and you are set to the wrong CAN ID for the main controller.
Your MegaSquirt is still running on CAN ID 0, so check this:
- In TunerStudio with your project open, press CTRL+P
The Project Properties dialog should open.
- Click the "CAN Devices" tab
- Check the setting "Main Controller CAN ID"
That should be set to 0, if not, set that to 0 and click OK
If that isn't it, turn on Comm Debug and try to connect again. Make a new Debug Package and post / send.
Thanks I'll try that when I get home
Ok. I reset the CAN I'd to 0 and it's working like a charm.. thanks very much for the help
Ok so I now have another issue
Since updating the firmware I am unable to get the engine to start..
ignition is firing I get plenty of spark but my injectors are not working
I tried using the port output test and am not getting any response from them ( I should be able to hear them buzz )
same results with both bank 1 and 2
any thoughts ???
MegaSquirt-II V3.57 plug and play for 1986-1993 5.0 Mustang
If I plug in the factory ECU the car will start....
any thoughts ???
Not sure how this is a TunerStudio issue ?
If you have a setup issue, best to post with tune and log into one of the ECU specific support sections.
I was just wondering because before the firmware update the car would start and run.....
