Complete Project Disappeared
turbo conversion
Post by turbo conversion »
I tried to open TS this morning (off line) and this is what I got, I can't find a clue of my project anywhere.
I've looked in every folder and there is not a trace of this project.
Everything was fine prior to a Dell up date, not sure if this had something to do with it or not.
Guess I need to start another project and detect the tune in the controller.
David
LT401Vette
Re: Complete Project Disappeared
Post by LT401Vette »
What is in your TunerStudioProjects folder?
Any chance it was accidentally dragged in to another folder?
turbo conversion
I can find all the msq and data log files but the project it self completely vanished.
If I had TS running in the back ground (and forgot it was running) and did the restart for the update could that do it?
David
LT401Vette
turbo conversion wrote: If I had TS running in the back ground (and forgot it was running) and did the restart for the update could that do it?
Doesn't seem likely. TS doesn't even have a Delete project function.
It writes to the file:
[ProjectFolder]/projectCfg/project.properties
and
CurrentTune.msq (if that is turned on)
That is unless your project is in the Temp folder. It does clean up the folder:
[TunerStudioProjectsFolder]/Temp/
turbo conversion
Oh well, I have no idea what happened but not going to worry about it any more.
Thanks for the response, I will just start a new project and go on.
David
