First sorry my English...
I have mind what missing from TS... Automatic system make AFR table... And them my mind to this...
I make VE table to perfect manual.. its good if TS can calculate new AFR table from VE table so later can use automatic correct
Another way is hard, drive and make AFR table whit manual.
If not catch my mind, ask free.
Another feature is calculate new VE and spark table... Mind: you make 16x16 ready but want change it to 16x32 and now its need make manual, why not just push button and its make to you new 16x32 or 32x16 table from old 16x16 ...
Feature...
Feature...
https://www.facebook.com/PikkiS-112502032715453/
https://www.theniceman.com/coppermine/
Ford Taunus Coupe 1975 2.0i Turbo
Ms3 + MS3x in Taunus
MS3 Pro Ultimate in PikkiS
Re: Feature...
Think to generate a half decent AFR table, you'd need to know the engine design. Outside the scope of most simple software.
Re: Feature...
Or use OS2 sensor read and save to afr table...DaveEFI wrote:Think to generate a half decent AFR table, you'd need to know the engine design. Outside the scope of most simple software.
And make when VE table is perfect and want make afr table show some.
Re: Feature...
The O2 sensor generally refers to the AFR table. But no reason not to note the AFR where it runs best at a specific load and base your AFR table on that. But you might then have to alter the VE table.
Re: Feature...
So any mind at make afr table from os2 sensor read ?
Re: Feature...
MegaLogViewer HD can do that using the Histogram / Table generator.NiceMan wrote:So any mind at make afr table from os2 sensor read ?
https://www.youtube.com/watch?v=CG_kY3K ... ture=share
