I have a lot of issue with the latest version of tuner studio.
I'm on my bench test and I want to reload different tunes and tunerstudio pop-up the compare tool. WHen I press send tuner settings most of the time it keep failing and popping the compare tune menu again.
if I close everything and I'm able to load the tune and test the ecu. Everything is fine.
If I power cycle the ecu, the tune compare can pop up again with odd parameters (while everything was fine just before the power cycle and no parameters changed)..
Issue compare tune with version 3.0.50.06
Re: Issue compare tune with version 3.0.50.06
The beta 3.0.50.06 is the 1st that is truly from the beta branch, not just a stable front runner.
There is an issue with sending a burning some settings in the wrong order. It can take a couple sends in cases.
It is not a problem with the difference reports, they are what saves the settings from getting lost. So keep that on and there will be a beta update shortly.
