AC shows on in TS even when conditions turn it off
jsdevel
Post by jsdevel »
In TS, whenever I have my AC switch turned on, the green light is on after the specified idle up delay, then it never turns off, even when I set min rpm artificially high and wait below that for a while. Is there a way to make the Green AC indicator in TS only come on when the AC output is actually on?
Re: AC shows on in TS even when conditions turn it off
Post by LT401Vette »
:msq:
What firmware?
jsdevel
Post by jsdevel »
MS2/extra-3.4.2
Sent from my Nexus 6P using Tapatalk
jsdevel
Post by jsdevel »
So I looked at the source for the MS2/extra-3.4.2-release firmware, and I don't think this is an issue with TS. The AC status ligh does turn on and off when I flip the switch on and off. I think outpc.status3 &= ~STATUS3_ACOUT; needs to be added to the if (outpc.rpm < flash12.ac_idleup_min_rpm) { block inside the idle_ac_idleup function. I'm going to try this tomorrow to see if it works. Assuming I can get it to work by updating the firmware, should I take this over to the MS2/Extra development board?
Also, is it acceptable for me to copy bits from the source code here in the forums?
jsdevel
Post by jsdevel »
That did the trick! AC light shuts off now when min rpm threshold is reached. I'll report this in MS2/Extra Development. Sorry for the false alarm here. Issue filed in the MS2 Development board here.
