Shadowdash 1.6.01 keep asking for Registration
Postby hobieboy » Wed Dec 13, 2017 1:10 pm
I installed v1.6.01 from v1.5.0 per this thread (viewtopic.php?f=122&t=67927) and now it keeps asking me to enter registration.
Information is entered and the message box indicating that registration successful and ShadowDash will exit now & upon restart registration will be there. But... after restarts, it asks for registration again.
Please help.
hobieboy
Re: Shadowdash 1.6.01 keep asking for Registration
Postby LT401Vette » Wed Dec 13, 2017 3:18 pm
So it never leaves demo mode?
This is registered through EFI Analytics, not Google play, correct?
Can you send us your App Debug:
- Swipe down
- touch the menu button in the top right
- touch File
- touch Advanced
- touch Share App Debug
It will put your appDebug.txt in an email to us.
LT401Vette
Postby kjones6039 » Wed Dec 13, 2017 6:47 pm
FWIW....... I, just today, updated to 1.6.01 without any such issue.........
MS2 v3 w/extra 3.4.2 Release
kjones6039
Postby hobieboy » Thu Dec 14, 2017 9:31 am
Hi Phil,
When I touch the File menu, I don't see Advanced. There's only: Log File Manager, Load/Save/Share Tune, Load/Reset/Share Dash, Share Project or Load Customer ini.
However, I ended up de-installing MS Dash then install it again. Now I have v1.6.01 and it never asked me to enter registration again (including first time after re-install) and my previously installed dashes are still there so as the logs.
So I suspect the problem I saw only happens when upgrading from v1.5.0?
hobieboy
Postby kjones6039 » Thu Dec 14, 2017 10:56 am
hobieboy wrote:So I suspect the problem I saw only happens when upgrading from v1.5.0?
FWIW once more........ As I stated above, I had no problem with the upgrade.......
kjones6039
Postby LT401Vette » Thu Dec 14, 2017 7:33 pm
Yeah, with SD it shouldn't matter what you upgrade from. It isn't like the PC apps where auto update applies deltas, with Shadow Dash it just downloads a new apk and installs it.
Look for a:
File --> Share Project
LT401Vette
Postby benckj » Sun Dec 17, 2017 1:52 pm
I'm stuck into Demo mode following upgrading to 1.6.01. Worked on my tablet but not on the Droid head unit I have installed in the car. I hate to uninstall my SD version and start from scratch in case I lose all my personal settings. Might just try and install again as being in Demo mode I keep getting reminders to register which for some reason causes a blip in my ignition system.
jim
MSPNP v2 with 3.57 firmware
Toyota MR2 98 3sgte
TD05sl2-18g (billet wheel & high flow turbine)
A2W IC
WI with 50/50 meth/water
benckj
Postby hobieboy » Mon Dec 18, 2017 6:46 am
After I un-installed SD and re-install as New, it did retain my dashes and previous data log, though YMMV.
Phil, do you mean to click on File->Share Project then Advanced will appear? Now that I have 1.6.01 not sure if I'll be able to re-produce it.
hobieboy
Postby LT401Vette » Mon Dec 18, 2017 7:42 am
benckj wrote:I'm stuck into Demo mode following upgrading to 1.6.01. Worked on my tablet but not on the Droid head unit I have installed in the car. I hate to uninstall my SD version and start from scratch in case I lose all my personal settings. Might just try and install again as being in Demo mode I keep getting reminders to register which for some reason causes a blip in my ignition system.
jim
Are you using the google play version or EFIA one?
If you uninstall and reinstall, you will loose your preferences, but not your project stuff (dashboards, data logs, ini files, etc.)
LT401Vette
Postby benckj » Mon Dec 18, 2017 10:21 am
I used google play version to upload.
Toyota MR2 98 3sgte
A2W IC
benckj
Postby sschutte » Mon Dec 18, 2017 11:08 am
duplicate post.
sschutte
Having issues with registrations/licences? Please email support@efianalytics.com from the email address used the licence was purchased. If you purchased through Google use your gmail account. If you purchased through efianalytics.com use the email address you filled in the form(The one the registration key was sent to).
Please include:
1) Name
2) Purchased thru : (Google / Efianalytics.com)
3) Short description and a of the issue
4) Callback number
We will contact you to troubleshoot the issue as soon as we have verified your purchase.
sschutte
Postby benckj » Mon Dec 18, 2017 7:24 pm
sschutte wrote:Having issues with registrations/licences? Please email support@efianalytics.com from the email address used the licence was purchased. If you purchased through Google use your gmail account. If you purchased through efianalytics.com use the email address you filled in the form(The one the registration key was sent to).
Please include:
1) Name
4) Callback number
OK will do except I actually bought 2 versions because I had problems before and doubt if you want to call me back as large time zone difference (NZ time).
When I get a chance and have Wifi connection to car I'll try a couple of things first.
jim
Toyota MR2 98 3sgte
A2W IC
benckj
Postby benckj » Wed Dec 20, 2017 1:50 am
Downloaded new version from EFI site and in order to use I had to submit name and registration key. I don’t have the key so email sent to you.
Jim
Toyota MR2 98 3sgte
A2W IC
benckj
Postby benckj » Wed Dec 20, 2017 10:35 am
Brian sent me the key so loaded in and all good now. Thanks again for your help.
Have activated the new economy gauge to read l/100km. Kind of strange to set the gauge limits though as low critical and high values are in reality reversed. Hardly want a red warning if I'm getting good gas milage!
Have not tested yet but want to use for economy driving when on the road. Like to have all my gauges with correct limits so can quickly see the colour change rather than trying to read value while driving.
Jim
Toyota MR2 98 3sgte
A2W IC
benckj
Postby benckj » Sat Jan 13, 2018 7:59 pm
Was doing some additional work with installing an Android tyre pressure monitoring system on my HU. During the install SD asked if I should download lasted 1.06.02 version. Sure why not I thought..... 2 hrs later I cannot get SD to run or even recognise my existence. Yes it will log into EFI but anytime I try and register, use existing license or even Buy App it ignores my input. Waited a day and just tried again with same result. Very Frustrating.
Am I the only one who is having problems here?
Toyota MR2 98 3sgte
A2W IC
benckj
Postby benckj » Sun Jan 14, 2018 1:53 am
I decided to visit google play store and view the latest SD program. Seems latest version is 1.6.03 where I recall upgrade options were for 1.6.02. Wonder if there is a bug in previous version causing an issue. Should I uninstall and reinstall again?
I’ve asked this before but just want to make sure current gauge settings are saved in file. I’ve kept it backed up during previous upgrades.
Toyota MR2 98 3sgte
A2W IC
benckj
Postby sschutte » Mon Jan 15, 2018 9:26 am
ShadowDash is sold on Google Play and through our the http://www.efianalytics.com website (You get a registration key). We distribute two different versions of the app to support the different payment mechanisms.
Users need to make sure to download/install the appropriate version of the app or they will be unable to activate the paid features.
Google users need to use the Play store download. The app will automatically activate paid features associated with that play store accunt.
Registry key users need to download the app from our download section: http://www.tunerstudio.com/index.php/downloads. The app will prompt you to enter your registration information on startup.
sschutte
Postby benckj » Mon Jan 15, 2018 10:34 am
SD prompted me to auto update which I did. Never got asked for register key and it got stuck in demo mode. I believe I have bought my APP through Google Play but have done this twice. When in Google and trying to open new version it states I’m an invalid user without asking for any additional information such as Rego Key (which I have). Only other option is uninstall which is probably my next option. See the dilemma?
Toyota MR2 98 3sgte
A2W IC
benckj
Postby benckj » Tue Jan 16, 2018 9:04 pm
As I have a Rego key I went into EFI link above to download new version which is already installed on my HU. Message came back it was unavailable from EFI site. Decided to roll back and install the 1.6.01 beta version which it did but failed to open. Still stuck in demo mode and connection to controller is intermittent. Help please!
Toyota MR2 98 3sgte
A2W IC
benckj
Next
Return to Tuner Studio
