Raspbian Pi3 TunersTudio no data from Bluetooth GPS
Posted: Sun Dec 17, 2017 7:15 am
Greetings,
I have a Qstarz 818XT GPS unit that I want to use with the Bluetooth channel to communicate with TunerStudio. This has worked well with Win10 both as a USB device and using Bluetooth.
Now I've started a Raspbian Pi3 with a touch screen, and I cannot get any GPS info to show up in TS . In the Raspbian Pi3 the GPS device is there, connected, paired and light is green and data communication is shown...but nothing in TS (TS MS v3.0.28). Bluetooth is enabled in TS. The Qstarz GPS blinking LEDs show that it is happy and transmitting data.
The Pi3 is running "Raspbian GNU/Linux 9 (stretch)"
What have I missed?
Martin
pi@raspberrypi:~ $ systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2017-12-17 10:42:59 CET; 4h 14min ago
Docs: man:bluetoothd(8)
Process: 1181 ExecStartPost=/usr/bin/sdptool add SP (code=exited, status=0/SUCCESS)
Main PID: 1125 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
└─1125 /usr/lib/bluetooth/bluetoothd -C --noplugin=sap
Dec 17 10:42:58 raspberrypi systemd[1]: Starting Bluetooth service...
Dec 17 10:42:58 raspberrypi bluetoothd[1125]: Bluetooth daemon 5.43
Dec 17 10:42:58 raspberrypi bluetoothd[1125]: Starting SDP server
Dec 17 10:42:58 raspberrypi bluetoothd[1125]: Excluding (cli) sap
Dec 17 10:42:58 raspberrypi bluetoothd[1125]: Bluetooth management interface 1.14 initialized
Dec 17 10:42:58 raspberrypi bluetoothd[1125]: Failed to obtain handles for "Service Changed" characteristic
Dec 17 10:42:58 raspberrypi sdptool[1181]: Serial Port service registered
Dec 17 10:42:59 raspberrypi systemd[1]: Started Bluetooth service.
What have I missed?
Martin
Status: "Running"
