The RPM REV limiter did not work(
Postby Valeriy » Sat Dec 30, 2017 10:25 am
Today I decided to write down the log file and there was a disaster! After I pressed the throttle on a neutral gear, my engine spun up instantly to 8025rpm, although the limiter was at 6000rpm. With such high revs my engine could not stand it and broke the pin of the gear on the crankshaft which goes to the gas distribution mechanism. Now I need to remove the heads of the block and change all 24 pieces of intake and exhaust valves at best. What I set up is not correct? What caused such a big engine speed? :(
мин.msq
My msd
(282.86 KiB) Downloaded 7 times
Срезало шпонку коленвала 2.jpg (318.56 KiB) Viewed 107 times
Срезало шпонку коленвала.jpg (224.94 KiB) Viewed 107 times
Valeriy
Re: The RPM REV limiter did not work(
Postby Reverant » Sat Dec 30, 2017 11:37 am
This is an MS3 generic support issue, not a TunerStudio issue.
Is either of "Fuel Cut" or "Spark Cut" enabled in the first picture?
The man behind MS Labs
2002 Mazda Miata 1.8 6sp - Enhanced MS3 1.4.0, sequential injection, sequential ignition, big turbo, lots of boost - InCar PC
Reverant
Postby 2swe » Sat Dec 30, 2017 12:10 pm
"Fuel Cut" or "Spark Cut" not enabled..
"spark retard" alone can not prevent the engine from overspeed.
2swe
Postby Valeriy » Sat Dec 30, 2017 9:21 pm
Reverant wrote:This is an MS3 generic support issue, not a TunerStudio issue.
Thank you for attention! It's my stupidity I missed these points cutting off the spark and fuel (I usually use a spark cut but this time I missed this which caused the engine to crash :( Now I'll go see the consequences, remove the heads of the block!
Valeriy
Postby Valeriy » Sat Dec 30, 2017 9:23 pm
2swe wrote:"Fuel Cut" or "Spark Cut" not enabled..
Thank you for attention! It's my stupidity I missed these points cutting off the spark and fuel (I usually use a spark cut but this time I missed this which caused the engine to crash :cry: Now I'll go see the consequences, remove the heads of the block!
Valeriy
Return to Tuner Studio
Users browsing this forum: Bing [Bot] and 2 guests
