over run fuel cut menu
lotus23C
Post by lotus23C »
Hi
After changing MS2extra firmware to the latest, I cannot access the over run fuel cut menu, it just won't open using a win 8.1 tablet. I have put the MSQ on my home PC and it opens up fine. Anyone else found this?
thanks
sschutte
Re: over run fuel cut menu
Post by sschutte »
This is odd, shouldn't be anything special with that dialog.
Please attach your MSQ file. This helps us get as close to your setup as possible making it easier to reproduce/troubleshoot the reported behavior.
What version of windows is on your home PC?
What version is your TunerStudio tablet vs PC?
Has the tablet been connected to a external monitor? (could the dialog be popping up outside the normal desktop area)
P.S.I just loaded ms2extra-release-3.4.2 firmware with default firmware tune on our bench MS2. The Over-run fuel cut menu came up just fine on my Windows 10 laptop running TunerStudio 3.0.28 (stable) and 3.0.50.40 (beta)
I will see if I can track down a Win8.1 PC that hasn't been upgraded to Win10..
LT401Vette
Post by LT401Vette »
Are you using the Beta TS?
There was an issue in recent betas where it would not display some Curve Graphs, this was fixed in 3.0.50.40 just last week..
If on the beta do a check for updates under the help menu.
lotus23C
Post by lotus23C »
sschutte wrote:This is odd, shouldn't be anything special with that dialog.
Thanks MSQ attached.
The attachment 20v CurrentTune.msq is no longer available
Win 8.1 on tablet
Win 10 on PC
Tablet TS version:3.0.28
Firmware freshly downloaded: 3.4.2
I have rebooted the tablet a few times with no difference, the menu features above and below over run still work.
Ironically the issue I am having with my tune is over run fuel cut - but cannot access it :cry:
thanks for your help
20v CurrentTune.msq
(119.01 KiB) Downloaded 31 times
turbo conversion
Post by turbo conversion »
I looked at your msq and over run fuel cut is there and opened for me :?
David
kjones6039
Post by kjones6039 »
turbo conversion wrote:I looked at your msq and over run fuel cut is there and opened for me :?
David
Yep........ Worked for me too!
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
lotus23C
Post by lotus23C »
Yea, works on my home PC and had to change the fuel cut settings by sending the file to that and then send back to tablet. I suppose the version on my tablet could be, for some reason, corrupt.
