Primary Ignition Load MAF mode
Postby sweet_baby_james » Fri Jan 12, 2018 10:10 pm
I've taken some time away from my turbo two-stroke project, finally getting back into in now with a MAF setup. I have the Primary Ignition Load set to MAF with a 650g/s MAF range selected (this is a 350cc motor, MAF is good for up to 400g/s) . In the Ignition Table 1 the y-axis is labeled 'ignload MAFload' and the bins defaulted as 20.1 to 100. Are these bins a % of the max range of the MAF sensor? In this case, the bins would be % of 650g/s? I have attached a picture of the table.
I haven't been able to find many posts where people are using MAF as the igntion load, even when MAF is used for fueling. Is it not common to use MAF for ignition load?
EFI and Turbo Yamaha RZ350
Microsquirt with MSExtra 3.3.2
sweet_baby_james
Return to MS3 General Support
