SD log filenames white in Night Shade mode
Running V3.0.50.40 but it certainly happens in 3.0.28 as well.
If you switch to the Night Shade mode and browse the SD card, the file names are in white, and the background color is also white, which means you can't see or read anything, unless you click on one and the background then becomes a darker color.
The man behind MS Labs
Re: SD log filenames white in Night Shade mode
I was able to reproduce the reported behavior on V3.0.28 but not V3.0.50.40. We are looking into it now.
Running on Linux if this makes any difference. Let me know if you also need the Java version.
This issue has been fixed. The fix should be in the next release.
Excellent, thank you!
Did this fix every get released? I am running TS MS 3.0.28 and having this problem....tkssschutte wrote:This issue has been fixed. The fix should be in the next release.
Scottie
Turbo LS Volvo 244
8.746 @ 154.94
Turbo LS Volvo 244
8.746 @ 154.94
It is fixed in the beta, soon to be stable.
