Request: Save EGO Sensor Calibration in .msq
Can I please request that the EGO sensor calibrations are saved in the .msq file so that the user can call up what the current calibration is at any time and also check retrospective tune files?
Currently it seems as though all the other sensor calibrations (TPS, Battery Voltage, MAP, Baro, Thermistor) have their calibration values saved for recall but the EGO sensor calibration gets wiped as soon as gets written to the controller making it impossible to verify exactly what calibration the ECU is actually using.
- Attachments
- AFR.PNG (28.64 KiB) Viewed 657 times
Re: Request: Save EGO Sensor Calibration in .msq
Agreed. It sucks guessing what is in there
If you are connected to the controller, TS goes through and CRC's the calibration tables and compares to the local solutions to find what is in the box.
In short, it will tell you what Sensor calibration is in the box when you are online.
Thanks Phil, Seeing the calibration when connected to the ECU is indeed helpful but I was more interested in seeing what calibration values were being used for historic tunes hence the request to save the cal to the .msq file. It is simply a verification/double checking step. The .msq saves all other sensor calibrations so why not the EGO sensor?
Because TS doesn't have direct visibility.motthomas wrote:Thanks Phil, Seeing the calibration when connected to the ECU is indeed helpful but I was more interested in seeing what calibration values were being used for historic tunes hence the request to save the cal to the .msq file. It is simply a verification/double checking step. The .msq saves all other sensor calibrations so why not the EGO sensor?
Each of those sensor calibrations are 1024 or 2048 bytes that TS generates and sends to the controller. The Firmware writes them directly to flash and uses them from there.
Once written TS can not command the page(s) are activated to RAM so TS can read them back, thus has no visibility to what is in there.
Eventually a crc was added so I can get the crc of the page(s). That let's me do brut-force attempt to match the calibration to the list of known solutions in TS for the online match, but once offline I got nothing to go by.
Offline visibility would require the firmware handling it differently which I would imagine is not trivial effort.
OK fair enough Phil. Thanks for the explanation. It sounds like its more hassle than it is worth. Better documentation on my own part should provide a workaround.
What prevents just storing the values in the .msq file?
I understand you can't read the values from the controller directly for verification, but you could store the user-entered values in the .msq then use the CRC to see if what''s in the ECU matches what's in the tune file. If no match, pop up a message, or show the entries as blank or whatever.
Eric Law
I recall adding placeholders for these a long while back, but for reasons I don't recall it didn't work out and they weren't used.
This should be done for all calibrations, not just the EGO.
The man behind MS Labs
It looks like it is already done for all other calibrations hence my request to do it for EGO.Reverant wrote:This should be done for all calibrations, not just the EGO.
In saying that, I'm not sure if TS will recognise if a coolant temp sensor cal in the ECU doesn't match what is in the .msq. I'll have a play tonight.
So I did a quick check last night and while TS does save all other sensor cals in the .msq, if the sensor cals are different between the ECU and msq, TS will read the ECU values and over-write the msq calibrations without a prompt or warning.
It is actually saved to the project, not msq.motthomas wrote:So I did a quick check last night and while TS does save all other sensor cals in the .msq, if the sensor cals are different between the ECU and msq, TS will read the ECU values and over-write the msq calibrations without a prompt or warning.
That's interesting. I would have expected the project to only be a high level file which contains basic settings and pointers to other files like dashboard layout and msq. Personally I would have considered sensor calibrations to be too detailed for the project.
Out of curiosity, what else is included in the project?
