36-1 trigger 1gt101dc
Postby vixen » Tue Jan 30, 2018 1:12 pm
ms2, 3.57, ms2 3.4.2 firmware
There's been a fair amount of forum chat about the 1gt101dc working with or not working with the a 36-1 crank trigger wheel. Both the items were procured from the diy web page with the assumption they would be compatible and hopefully they will be. With the trigger/1gt combination coupled to a 350 rpm drill the megatune tach spikes at around 5K rpm which isn't reflected well in the data log. With a ford tfi distributor coupled to the drill the megatune tach shows a more correct 300ish rpm which also isn't reflected well in the data log. The ms2 jumpers have been configured as per the megatune manual. Suggestions welcome and buying another sensor better suited to the 36-1 trigger wheel is a palatable option. At this point the goal is to have megasquirt and crank trigger time both the coil signal passing through a sb ford distributor and fuel injectors via tps.
Thanks, Kevin Wallace
2018-01-30_11.13.33.msl drill tfi.msl
(170.64 KiB) Downloaded 2 times
vixen
Return to Tuner Studio
Users browsing this forum: Motoren and 2 guests
