Page 1 of 1
Battery voltage too low configuration error message
Posted: Sun Feb 04, 2018 4:16 pm
by NigeT
I have been trying to get cold start to work and intermittently get this message. I recycle the ignition and all is well again. The error message gives me no clue where to look for the configuration error so I don't know what to fix.
Any ideas? I'll try to remember to screenshot it next time.
Thanks, Nigel.
Sent from my SM-N950F using Tapatalk
Re: Battery voltage too low configuration error message
Posted: Sun Feb 04, 2018 4:41 pm
by BlackBird_SR71
Post a Data-Log next time and we may be able to see something.
Posted: Sun Feb 04, 2018 4:46 pm
by jsmcortina
NigeT wrote:The error message gives me no clue where to look
How about the battery voltage?
Posted: Sun Feb 04, 2018 4:47 pm
by NigeT
jsmcortina wrote:NigeT wrote:The error message gives me no clue where to look
Doesn't seem like a configuration error and it recovers immediately without charging.
Posted: Tue Feb 06, 2018 6:11 am
by Reverant
This usually happens on the Miata during cranking when there's false sync and there's starter kickback due to an ignition event at the wrong time. It's somewhat annoying as most users can't tell that it has happened during cranking, and they keep cranking while the ECU is in error mode.
Posted: Tue Feb 06, 2018 8:54 am
by NigeT
Reverant wrote:jsmcortina wrote:NigeT wrote:The error message gives me no clue where to look
That fits. The last time it happened (last night) was during a failed start attempt, one of many. One had a backfire, but I don't remember if it immediately preceeded this message.
Is there any way to prevent the bad syncing?
Posted: Sat Mar 31, 2018 2:18 pm
by jsmcortina
Reverant wrote:This usually happens on the Miata during cranking when there's false sync and there's starter kickback due to an ignition event at the wrong time. It's somewhat annoying as most users can't tell that it has happened during cranking, and they keep cranking while the ECU is in error mode.
I encountered it today... and edited the code to remove it for the next beta.
Posted: Sat Mar 31, 2018 2:55 pm
by Manu
For MS2 code or for MS3 one ?
Posted: Sat Mar 31, 2018 3:49 pm
by jsmcortina
Manu wrote:For MS2 code or for MS3 one ?
It was only in MS3.
Posted: Sun Apr 01, 2018 7:52 am
by Reverant
jsmcortina wrote:Reverant wrote:This usually happens on the Miata during cranking when there's false sync and there's starter kickback due to an ignition event at the wrong time. It's somewhat annoying as most users can't tell that it has happened during cranking, and they keep cranking while the ECU is in error mode.
Great, thank you.
Please have a look at the sync code for the 4G63 and Miata 99-05, there's at least 50% chance that there will be a starter kickback during cranking when the engine is cold.
Posted: Mon Apr 02, 2018 3:45 am
by prof315
Reverant wrote:jsmcortina wrote:Reverant wrote:This usually happens on the Miata during cranking when there's false sync and there's starter kickback due to an ignition event at the wrong time. It's somewhat annoying as most users can't tell that it has happened during cranking, and they keep cranking while the ECU is in error mode.
Great, thank you.
It tends to get worse as the engine's static compression rises.
