Error warning message
I get the warning message on project load despite Options / Advanced / Report INI warnings being switched off.
W10
TS: 3.0.28
FW : MSX 3.2.4
W10
TS: 3.0.28
FW : MSX 3.2.4
Kind regards
Philip
Philip
Re: Error warning message
What is the message? W10?
W10 = Windows 10 (Sorry!)
Error message attached.
Kind regards
Philip
Philip
It won't prompt you on warnings unless it is turned on under the Advanced menu.
However, TS will always prompt you with Errors. In that screenshot there are 52 errors.
What are the errors?
custom.ini file attached. I can't figure out what the problem is.
52 Errors:
Error: Malformed [OutputChannel] entry, Problem at:
[custom.ini]:[Line:751]: entry = time, "Time", float, "%.3f"
[custom.ini]:[Line:752]: entry = seconds, "SecL", int, "%d"
[custom.ini]:[Line:753]: entry = rpm, "RPM", int, "%d"
[custom.ini]:[Line:754]: entry = map, "MAP", float, "%.1f"
[custom.ini]:[Line:756]: entry = throttle, "TP", int, "%d"
[custom.ini]:[Line:757]: entry = batteryVoltage, "vBatt", float, "%.2f"
[custom.ini]:[Line:759]: entry = afr1, "Actual AFR", float, "%.2f"
[custom.ini]:[Line:760]: entry = afrtgt1, "AFRtrgt1", float, "%.2f"
[custom.ini]:[Line:761]: entry = afrerr1, "AFR Error", float, "%.1f"
[custom.ini]:[Line:763]: entry = mat, "IAT", float, "%.1f"
[custom.ini]:[Line:764]: entry = coolant, "CLT", float, "%.1f"
[custom.ini]:[Line:765]: entry = engine, "Engine", int, "%d"
[custom.ini]:[Line:768]: entry = airCorrection, "Gair", int, "%d"
[custom.ini]:[Line:769]: entry = warmupEnrich, "Gwarm", int, "%d"
[custom.ini]:[Line:770]: entry = baroCorrection, "Gbaro", int, "%d"
[custom.ini]:[Line:771]: entry = gammaEnrich, "Gammae", int, "%d"
[custom.ini]:[Line:772]: entry = accDecEnrich, "AccelEnrich", int, "%d"
[custom.ini]:[Line:774]: entry = veCurr1, "Gve", int, "%d"
[custom.ini]:[Line:775]: entry = pulseWidth1, "PW", float, "%.3f"
[custom.ini]:[Line:776]: entry = dutyCycle1, "DutyCycle1", float, "%.1f"
[custom.ini]:[Line:778]: entry = advance, "SparkAdv", float, "%.1f"
[custom.ini]:[Line:779]: entry = coldAdvDeg, "ColdAdv", float, "%.1f"
[custom.ini]:[Line:780]: entry = tpsDOT, "tpsDOT", float, "%.1f"
[custom.ini]:[Line:781]: entry = mapDOT, "mapDOT", float, "%.1f"
[custom.ini]:[Line:782]: entry = iacstep, "IAC", int, "%d"
[custom.ini]:[Line:784]: entry = deltaT, "deltaT", float, "%.0f"
52 Errors:
- Attachments
- custom.ini
- (30.85 KiB) Downloaded 19 times
Kind regards
Philip
Philip
I deleted all the datalog stuff and now my errors are gone. Am I right that the datalogging parameters in mainController.ini will still apply?
Kind regards
Philip
Philip
It looks like your DataLog entries are in your OutpuChannels section.
did the [Datalog] section header get deleted?
Yes, I deleted that as well.LT401Vette wrote:It looks like your DataLog entries are in your OutpuChannels section.
Kind regards
Philip
Philip
