Hi
Im installing MS2 on my gsxr1100, and will use an shadow dash on tablet to display everything.
Is it possible to use a digital input as an indicator? I can not find them under the output channel list.
And is it possible to add an indicator for output status? ex. if the fan is on or off?
\\ Redracing
add indicator for digital input (pe0/pa0)
Re: add indicator for digital input (pe0/pa0)
Checking the TunerStudio Lite manual for MS2 Extra in the link above, in the PORT_STATUS section:
it looks like you need bit 1 of portbde for pe0
indicator = { portbde & 1 }, "PORTE0", "PORTE0", white, black, green, black
and bit 1 of portam for pa0
indicator = { portam & 1 }, "PORTA0", "PORTA0", white, black, green, black
If you turn on PORT_STATUS on the settings tab of project properties, these 2 (with many others) will show on your right click menu.
