I am just putting this out there because it's something I noticed between two installations on two different macs I own.
On my fairly powerful iMac i7, 16gb ram, etc...
When I click on the red circle (x) in the top left corner of the window, it takes 5.45 seconds to quit.
When I select File>Exit it takes about the same amount of time.
If I use the Mac Menu Bar of "Tunerstudio MS">Quit or command-Q it takes 1:01 to quit.
Any thoughts?
Tunerstudio Mac app quit/exit times
Re: Tunerstudio Mac app quit/exit times
I've learned to close the Tune first, and then TunerStudio.
Just quiting Tunerstudio with a Tune open takes forever.
When you use the Mac menu bar it cuts TS off at the knees and skips a lot clean up.
I have had to add a hook to do the minimal clean up.
