I have been testing some hardware and software for the 4-0 long tooth trigger wheel found on a lot of sport bikes, regardless of the responses i will be posting the modified firmware and hardware schematic, my question is would anyone be interrsted in such hardware becuase i have designed the pcb as well, but have yet to test that version (mine is perfboard atm), and depending on the response may look into having the board produced
edit*
bassed off matt_gsxr's with a few fixes
r56 ~6-8 turns
if you don't get a signal swap vr signal (there is a polarity)
and firmware, this is 3.3.0b
**FIRMWARE HAD ISSUES WILL BE FIXING***
i had a rough firmware that was working great and i tried to clean it up and messed something up i will be fixing it shortly
