Do CANBUS instruments match MS2
Dutchredhead
Post by Dutchredhead »
I find it hard to confirm to myself if the MS2 CANBUS is able to directly communicatie/work with CANBUS instruments.
Was looking into SPeedhut instruments, amongst others. Their support desk can't confirm MS2 to work and the support page is made arround standard OBD CAN communication.
http://www.speedhut.com/faq.i#how-can-i ... n-protocol
I'm trying to confirm the CAN protocol they rever to, J1979 is what MS2 can work with.
Second to that, when OBDII is J1979 CANBUS and MS2 would indeed be able to work with, would that imply I could have a BMW E90 cluster work with that CANBUS signal as well?
E28 525e -M20B27- DIS, MS2 V3.0
Re: Do CANBUS instruments match MS2
Dutchredhead wrote:I'm trying to confirm the CAN protocol they rever to, J1979 is what MS2 can work with.
No, that's not supported.
Your dash is extremely unlikely to be using J1979, almost certainly it will use proprietary, undocumented raw messages on the CAN.
Dutchredhead
Thanks James.
I found this document http://www.msextra.com/doc/pdf/Megasqui ... adcast.pdf which says it is 11Bit Can.
And with DIY on their support page it has a list of meters/applications that would work.
https://www.diyautotune.com/support/tec ... lays-data/
What is the "Simplified Dash Broadcasting" refering to? What sort of dash instruments? That is what confuses me here.
Dutchredhead wrote:What is the "Simplified Dash Broadcasting" refering to? What sort of dash instruments? That is what confuses me here.
Any aftermarket programmable dash that supports that data format.
Dutchredhead
Oké thanks.
Than I'm only able to do the ones on the DIY list.
