by Joe » Wed May 27, 2009 6:46 pm
James,
Help-
Running MSII v3 Latest Alpha 3.something (Working great, Love the closed loop Idle)
Microsquirt v2 running .009 trans code.
Setup CAN to fetch RPM, TPS and engine temp. Working good.
In trans range 4, 65 mph 10% tps I do not have TCC apply.
Gauge shows TCC ramping up nicely to 70% but no ground on INJ1.
I loaded MSextra on my microsquirt. Entered output mode. Was able to turn on INJ1 and INJ2.
Convinced(at least right now) my hardware is working.
I am bench testing at the moment, I just picked up my 4l80E today.
Notes on my bench setup-
I am using am old stim board. VSS is fed to the optical circuit. MPH reading ok.
I don't have a range switch at the moment. I tested channel ABC of TPT. Working good.
Edit:Don't recall 3
It's wired so on power up I am in TPT4 65mph. After the delay megatune shows TCC ramp up but my INJ1 does not supply ground. I am hoping to install the 4L80E(Also selected in my INI) sometime in the next week.
Any advice you are willing to give would be much appreciated.
Thanks,
Joe
78 Chev 4x4 MSII extra(Some days MS3) Microsquit 4l80E (Toy Hauler/Beta test rig )
69 Camaro MSII Extra(Totaled 11-2011-R.I.P)
70 AAR Cuda -Hanger queen- 340 MS3 Seq- XV Level II - Work in Progress - Summer 2013???
